[postgis-devel] Raster Regress
Paragon Corporation lr at pcorp.us
Tue Jan 3 22:47:23 PST 2012
Paul,
What do your regress files look like?  Would be good if you submitted a
ticket so we can take a look -- with regress failure files attached.
The uninstall failure is kind of troubling too.
Thanks,
Regina
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On
> Behalf Of Paul Ramsey
> Sent: Tuesday, January 03, 2012 7:27 PM
> To: postgis-devel at postgis.refractions.net
> Subject: [postgis-devel] Raster Regress
> Kind of a re-run from earlier, but is raster supposed to
> regress clean? This is what I get...
>  PostgreSQL 9.1.2 on x86_64-apple-darwin10.8.0, compiled by
> i686-apple-darwin10-gcc-4.2.1 (GCC) 4.2.1 (Apple Inc. build
> 5666) (dot 3), 64-bit  Postgis 2.0.0SVN - 2012-01-04 00:21:04
>    GEOS: 3.2.4-CAPI-1.6.4
>    PROJ: Rel. 4.7.1, 23 September 2009
>    GDAL: GDAL 1.8.1, released 2011/07/09
> Running tests
>  check_raster_columns .. ok
>  check_raster_overviews .. ok
>  rt_io .. ok
>  rt_bytea .. ok
>  box3d .. ok
>  rt_addband .. ok
>  rt_band .. ok
>  rt_asgdalraster .. failed (diff expected obtained:
> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_8_diff)
>  rt_astiff .. failed (diff expected obtained:
> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_9_diff)
>  rt_asjpeg .. failed (diff expected obtained:
> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_10_diff)
>  rt_aspng .. failed (diff expected obtained:
> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_11_diff)
>  rt_union .. ok
>  create_rt_properties_test .. ok
>  rt_dimensions .. ok
>  rt_scale .. ok
>  rt_pixelsize .. ok
>  rt_upperleft .. ok
>  rt_rotation .. ok
>  rt_georeference .. ok
>  rt_set_properties .. ok
>  drop_rt_properties_test .. ok
>  create_rt_empty_raster_test .. ok
>  rt_isempty .. ok
>  rt_hasnoband .. ok
>  drop_rt_empty_raster_test .. ok
>  rt_metadata .. ok
>  create_rt_band_properties_test .. ok
>  rt_band_properties .. ok
>  rt_set_band_properties .. ok
>  rt_summarystats .. ok
>  rt_count .. ok
>  rt_histogram .. ok
>  rt_quantile .. ok
>  rt_valuecount .. ok
>  rt_valuepercent .. ok
>  rt_bandmetadata .. failed (diff expected obtained:
> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_36_diff)
>  rt_pixelvalue .. ok
>  drop_rt_band_properties_test .. ok
>  rt_utility .. ok
>  create_rt_mapalgebra_test .. ok
>  rt_mapalgebraexpr .. ok
>  rt_mapalgebrafct .. ok
>  rt_mapalgebraexpr_2raster .. failed (diff expected obtained:
> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_43_diff)
>  rt_mapalgebrafct_2raster .. failed (diff expected obtained:
> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_44_diff)
>  drop_rt_mapalgebra_test .. ok
>  create_rt_mapalgebrafctngb_test .. ok
>  rt_mapalgebrafctngb .. ok
>  rt_mapalgebrafctngb_userfunc .. ok
>  drop_rt_mapalgebrafctngb_test .. ok
>  rt_reclass .. ok
>  rt_resample .. failed (diff expected obtained:
> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_51_diff)
>  rt_asraster .. failed (diff expected obtained:
> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_52_diff)
>  rt_intersection .. failed (diff expected obtained:
> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_53_diff)
>  create_rt_gist_test .. ok
>  rt_above .. ok
>  rt_below .. ok
>  rt_contained .. ok
>  rt_contain .. ok
>  rt_left .. ok
>  rt_overabove .. ok
>  rt_overbelow .. ok
>  rt_overlap .. ok
>  rt_overleft .. ok
>  rt_overright .. ok
>  rt_right .. ok
>  rt_same .. ok
>  drop_rt_gist_test .. ok
>  rt_spatial_relationship .. ok
>  rt_intersects .. ok
>  rt_samealignment .. ok
>  bug_test_car5 .. ok
>  uninstall ... failed (Count of object before install (3855)
> != count after uninstall (3872))
> postgis-devel mailing list
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
