[postgis-devel] [PostGIS] #1424: tickets error on check phase
PostGIS trac at osgeo.org
Wed Jan 4 01:22:45 PST 2012
 Reporter:  aperi2007  |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  postgis    |     Version:  trunk
 Keywords:             |
Comment(by aperi2007):
 I'm analyzing the failed test.
 The failed test is this:
 ST_Segmentize(ST_GeomFromEWKT('PolyhedralSurface( ((0 0 0, 0 0 1, 0 1 1, 0
 1 0, 0 0 0)), ((0 0 0, 0 1 0, 1 1 0, 1 0 0, 0 0 0)), ((0 0 0, 1 0 0, 1 0
 1, 0 0 1, 0 0 0)), ((1 1 0, 1 1 1, 1 0 1, 1 0 0, 1 1 0)), ((0 1 0, 0 1 1,
 1 1 1, 1 1 0, 0 1 0)), ((0 0 1, 1 0 1, 1 1 1, 0 1 1, 0 0 1)) )'), 0.5);
 I notice a difference with the others test in the same tickets set.
 All the other call to ST_GeomFromEWKT will have the SRID explicitly
 declared.
 ST_GeomFromEWKT('SRID=4326;POLYGONM(...
 This instead no.
 ST_GeomFromEWKT('PolyhedralSurface(...
 I guess is here the problem.
 Now try to do some tests....
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1424#comment:5>
