[postgis-devel] [PostGIS] #1431: Regression failures in topology under cassert
trac at osgeo.org
Thu Jan 5 03:04:35 PST 2012
Reporter: pramsey | Owner: strk
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.0.0
Component: topology | Version: trunk
Resolution: fixed | Keywords:
Comment(by mcayland):
Is it really as simple as changing the language from SQL to PLPGSQL? If
so, you should file a bug report with -hackers.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1431#comment:4>
