[postgis-devel] Vote on Merging postgis and raster installs andwhen
Chris Hodgson
chodgson at refractions.net
Thu Jan 5 10:41:50 PST 2012
Paul if you read your geos-devel e-mail I think the release of GEOS
3.3.2 is just waiting on your special upload powers.
Chris
On 12-01-05 10:37 AM, Paul Ramsey wrote:
> \On Thu, Jan 5, 2012 at 2:55 AM, Mark Cave-Ayland
> <mark.cave-ayland at siriusit.co.uk> wrote:
>> On 03/01/12 19:54, Paul Ramsey wrote:
>>> I think GDAL should be mandatory, but older GEOS should be OK (we've
>>> gone to the trouble of stubbing those functions for a reason,
>>> presumably. A configure WARNING makes sense, so at least ignorance
>>> won't be an excuse.
>> Hmmm but doesn't this undermine your earlier argument about keeping
>> everything the same? The reason I spent time making PROJ/GEOS mandatory was
>> because of the many issues we had stemmed from developers having different
>> combinations of libraries installed - so for example I could commit a patch
>> against PostGIS and have it pass regression without having PROJ installed
>> locally, whereas someone else with PROJ could have it fail regression
>> because it was never checked on my system.
>> I'd much prefer to bump the minimum version of GEOS to give both users and
>> developers a consistent experience rather than to keep stubbing functions
>> against various different versions :(
> Yes it does undermine it, but it's not quite the same argument. If we
> were talking about versioning liblwgeom and installing it separately
> and then allowing PostGIS to work against different versions of that
> (and by gum if we didn't have that conversation, almost made me blow
> my brains out) then it would be the same argument. GEOS is a separate
> project and it's not unreasonable to expect people will have different
> versions of it floating around and to maintain at least a little
> backward compatibility to allow installation flexibility for folks.
> The grey area is how *much* backward compatibility.
> I'll note that as of now, logic dictates that we have *no* backward
> compatibility, because (a) topology should be a default build
> component and (b) topology requires GEOS>= 3.3.2 (Arg!!! minor
> version requirement!) and (c) that version of GEOS isn't even released
> yet!
> Sandro, is there anything preventing us popping out a minor GEOS
> release in short order so that when PostGIS 2alpha comes out it's not
> depending on an unreleased library?
> p.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
