[postgis-devel] [PostGIS] #1437: Provide standard Makefile rules for java components
trac at osgeo.org
Mon Jan 9 03:15:23 PST 2012
Reporter: strk | Owner: delawen
Type: task | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: Java bindings | Version: trunk
Keywords: |
We need the following Makefile rules for java components:
* all - builds what needs to be built...
* clean - removes built files
* distclean - what clean does plus removes whatever was generated by
./configure
* check - runs regress tests
I understand the new preferred build tool for java components is maven,
but even if so we want to wrap maven calls into Makefile rules.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1437>
