[postgis-devel] [PostGIS] #1412: ST_Intersects not using indices
trac at osgeo.org
Mon Jan 9 03:56:35 PST 2012
Reporter: strk | Owner: strk
Type: defect | Status: closed
Priority: critical | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Resolution: worksforme | Keywords:
Comment(by robe):
correct the _st s should be strict. It's just where you need the sql to be
able to break into its parts that can't be strict.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1412#comment:5>
