[postgis-devel] [PostGIS] #1392: Can't geocode an intersection that should work
trac at osgeo.org
Mon Jan 9 06:58:21 PST 2012
Reporter: arencambre | Owner: robe
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.0.0
Component: tiger geocoder | Version: trunk
Resolution: fixed | Keywords:
Changes (by robe):
* status: assigned => closed
* resolution: => fixed
Comment:
should be fixed at r8713. It was my assumption that everything should
have an addr record and the addr record should have a zip which is often
not the case for highways.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1392#comment:3>
