[postgis-devel] [PostGIS] #1440: [raster] Support for offline band data
trac at osgeo.org
Mon Jan 9 08:18:59 PST 2012
Reporter: dustymugs | Owner: dustymugs
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Add functionality to load offline bands so that the PostGIS raster
functions can be used. The data will be read-only instead of read-write
due to several issues:
1. filesystem privileges: will the user account that the postgres process
have write access to the raster file and containing directory?
2. offline raster format: does the format of the offline raster permit
direct modification of a band value or is an intermediary format required?
Once read-only access is complete, the out_db column of raster_columns
view will be reintroduced. In the new iteration of the out_db column, it
will be an array of booleans where each element indicates that the band's
data is offline.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1440>
