[postgis-devel] [PostGIS] #1392: Can't geocode an intersection that should work
trac at osgeo.org
Mon Jan 9 21:18:48 PST 2012
Reporter: arencambre | Owner: robe
Type: defect | Status: reopened
Priority: medium | Milestone: PostGIS 2.0.0
Component: tiger geocoder | Version: trunk
Resolution: | Keywords:
Comment(by robe):
It's not part of the upgarde minor 2.0 script because its not always
installed and also a lot of people on 1.5 are using it. Things in the
extras folder are never installed as part of the core PostGIS.
Sorry I should clarify that better in the docs (probably in the install
sectin where a lot of people are looking). You want to run the
extras/tiger_geocoder/tiger_2010/upgrade_geocoder.sh or
upgrade_geocoder.bat file
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1392#comment:6>
