[postgis-devel] [PostGIS] #1418: Fix up errors in new loader GUI and add dumper support
trac at osgeo.org
Wed Jan 11 02:19:02 PST 2012
Reporter: mcayland | Owner: mcayland
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.0.0
Component: loader/dumper | Version: trunk
Keywords: |
Comment(by mcayland):
Thanks for the feedback :)
Per your request, I enabled resizing of the filename column which I
believe should be sufficient? The other columns are generally quite small
and set to auto-size themselves based upon the content, so you won't ever
need to resize them. I'm not sure I understand your comment about
information is sometimes not take unless you click on a row? It sounds
like this may be some kind of GTK bug - which version are you running?
In terms of the mode dropdown, here I see that GTK aligns the drop-down
based upon its currently selected value. Note that this behaviour is
unchanged from Mark's version, and I'm not sure whether you can always
make it drop lower? This may need some research.
Finally the reason that the geometry column takes so much space is because
it is set to auto-size, it currently sizes itself based upon the column
title which is "Geometry Column". If you would like to suggest a shorter
column name I'd be happy to change it.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1418#comment:10>
