[postgis-devel] [PostGIS] #1444: Hudson is failing on trunk
trac at osgeo.org
Thu Jan 12 05:02:40 PST 2012
Reporter: robe | Owner: chodgson
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: management | Version: trunk
Keywords: |
Comment(by robe):
Chris,
Any luck with this. Like I said I don't think the document building is
the culprit because it builds the PDF successfully. What I do notice
comparing the last success:
http://office.refractions.net:1500/job/PostGIS-trunk-build/3609/
With the failures is that the failed ones don't have these lines after
successful build of the PDF:
+ rm -f postgis.xml
+ mv postgis.xml.orig postgis.xml
++ grep Error doc-errors.log
++ wc -l
+ '[' 0 -gt 0 ']'
+ cd /var/home/buildbot/opt/hudson/jobs/PostGIS-trunk-build/workspace
+ /bin/cp build/doc/postgis-2.0.0SVN.pdf rel/doc
+ /bin/cp -r build/doc/html rel/doc
+ mv rel postgis-2.0.0SVN
+ tar cfz postgis-2.0.0SVN.tar.gz postgis-2.0.0SVN
+ echo SVN_REVISION=8715
+ echo POSTGIS_MAJOR_VERSION=2
+ echo POSTGIS_MINOR_VERSION=0
+ echo POSTGIS_MICRO_VERSION=0SVN
So it seems to be something is going wrong when its trying to clear out
files. The failed ones just culminate in a after the successful PDF build.
+ exit 1
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1444#comment:7>
