[postgis-devel] [PostGIS] #1383: Topology: ST_AddEdgeNewFaces() fail to add an edge
trac at osgeo.org
Thu Jan 12 06:36:05 PST 2012
Reporter: aperi2007 | Owner: strk
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.0.0
Component: topology | Version: trunk
Keywords: |
Comment(by strk):
Adding debugging calls fixes it as well, so _really_ look like memory
handling bug.
Here's an excerpt of debugging from of a working session:
DEBUG: p1: POINT(-0.2 0.4)
DEBUG: p2: POINT(-2.77555756156289e-17 0.4)
DEBUG: bounds: LINESTRING(0.1 0.3,-0.1 0.2,-0.1 0.1,-0.1
1.38777878078145e-16,0.2 -0.2,0.2 -0.4,-0.2 -0.4,-0.4 -0.4,-0.4 0.4,-0.3
0.4,-0.2 0.4,-2.77555756156289e-17 0.4,0.1 0.4,0.1 0.3)
DEBUG: LocatePoint(bounds,p1): 0.865959016295581
DEBUG: LocatePoint(bounds,p2): 0.93297950814779
DEBUG: Edge 30 (left:0, right:0) - ring : {0} - right_side : t
When it fails one of the ST_Locate_Point returns 0, swapping right/left
side.
So could be related to ST_Locate_Point.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1383#comment:4>
