[postgis-devel] [PostGIS] #1444: Hudson is failing on trunk
    trac at osgeo.org
    Thu Jan 12 11:42:42 PST 2012
  Reporter:  robe        |       Owner:  chodgson
      Type:  defect      |      Status:  closed
  Priority:  medium      |   Milestone:  PostGIS 2.0.0
 Component:  management  |     Version:  trunk
Resolution:  fixed       |    Keywords:
Changes (by chodgson):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 The "exit 1" is coming from the test grepping the output of the doc build
 for "error" - guess what, it finds lots of errors mentioned, even though
 it eventually finishes with "successful build" - so I changed that check
 to grep for "successful build" instead, and only "exit 1" if  it doesn't
 find it.
 We now have a happy Hudson build of trunk!
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1444#comment:9>
