[postgis-devel] Documentation and comments in tarball
Greg Troxel
gdt at ir.bbn.com
Fri Jan 13 06:34:40 PST 2012
Sandro Santilli <strk at keybit.net> writes:
> On Tue, Jan 10, 2012 at 08:30:38PM -0500, Greg Troxel wrote:
> Note that building docs is not mandatory, they aren't built by default.
> If all you need is _reading_ the manual you have convenient separate
> downloads here: http://www.postgis.org/documentation/
What I am trying to do is prepare a complete binary package for postgis,
for use by other people who might or might not be offline.
> From a packaging point of view I think docs should be in a separate
> package as well (postgis-doc).
Perhaps, but whether to bundle or split docs is a package system
cultural choice (pkgsrc tends not to split as much as most Linux
packaging systems, only splitting when including is painful and likely
unwanted by many), and I think orthogonal to all these issues.
[three issues in 1.5.3, two of which were fixed in trunk already, all
of which are fixed in trunk and 1.5 branch now]
Thanks for these changes.
[reports w/o patches]
OK - I'll start on tickets for those issues (and ignore 1.5).
Also, trunk r8794 has one minor failure (looks to be a test assumption
issue, not a real bug) on:
PostGIS is now configured for i386-unknown-netbsdelf5.1.
-------------- Compiler Info -------------
C compiler: gcc -g -O2
C++ compiler: g++ -g -O2
-------------- Dependencies --------------
GEOS config: /usr/pkg/bin/geos-config
GEOS version: 3.3.2
PostgreSQL config: /usr/pkg/bin/pg_config
PostgreSQL version: PostgreSQL 8.4.10
PROJ4 version: 47
Libxml2 config: /usr/pkg/bin/xml2-config
Libxml2 version: 2.7.8
JSON-C support: No
PostGIS debug level: 0
and the rest of the tests pass.
On
loader/Latin1 ... failed ( wkb test: running shp2pgsql output: /tmp/pgis_reg_17179/loader.err)
I get:
psql:/tmp/pgis_reg_9886/loader.out:7: ERROR: value too long for type character varying(32)
and sure enough the insert statement seems to have more than 32 characters.
Is this known, or should I file a ticket?
(I can easily test with 8.3, 8.4, 9.0, and 9.1, but as 8.4 is the
current pkgsrc default I am trying that first.)
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20120113/56d195cd/attachment.sig>
