[postgis-devel] [PostGIS] #748: shp2pgsql use wrong schema name
trac at osgeo.org
Fri Jan 13 16:51:44 PST 2012
Reporter: aperi2007 | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS Future
Component: loader/dumper | Version: trunk
Keywords: |
Comment(by mcayland):
Note as of r8807 you should now be able to specify --with-gettext=no to
configure in order to explicitly disable NLS at build time (this seems
much more preferable as a temporary solution rather than you having to
keep patching the source tree).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/748#comment:38>
