[postgis-devel] [PostGIS] #1465: loader/Latin1 regression failure (NetBSD, postgresql 8.4.10)
PostGIS trac at osgeo.org
Sat Jan 14 07:37:13 PST 2012
 Reporter:  gdt            |       Owner:  mcayland
     Type:  defect         |      Status:  new
 Priority:  medium         |   Milestone:  PostGIS 2.0.0
Component:  loader/dumper  |     Version:  trunk
 Keywords:                 |
Comment(by gdt):
 If I nuke the pgsql database dir and recreate with LC_ALL=en_US.UTF-8,
 then the regression test passes without my modification.  But even with
 the modification, creating the database without LC_ALL set (and hence
 SQL_ASCII encoding) causes the test to fail with value too long (because
 there are 35 bytes in the UTF-8 encoding of the test address, which don't
 fit in varchar(32)).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1465#comment:3>
