[postgis-devel] [PostGIS] #1471: gist geometric equality operator - for geometry uniqueness constraints
PostGIS trac at osgeo.org
Sun Jan 15 12:23:31 PST 2012
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS Future
Component:  postgis  |     Version:  trunk
 Keywords:           |
Description changed by robe:
Old description:
> The geometric equality operator we used to have in 1.3 (~=) would be even
> more useful now.  We can't call it ~= since that has already changed
> definition so much and is now just a bounding box equality (and not even
> that much because our bounding boxes are floats instead of the double
> precision of the geometry)
> Something like  == might be a possible choice for bringing back the good
> old geometric equality ~= (NOTE this requies it have a RECHECK on it.
> The main benefit would be to be able to use exclusion constraints
> (introduced in PostgreSQL 9.0) to enforce geometry uniqueness.  Right now
> there is no guaranteed way of doing this and EXCLUSION CONSTRAINTS won't
> work with functions (so ST_OrderingEquals is out of the question) -- they
> have to be operators.
> http://www.postgresql.org/docs/9.0/static/sql-createtable.html#SQL-
> CREATETABLE-EXCLUDE
New description:
 http://www.postgresql.org/docs/9.0/static/ddl-constraints.html
 http://thoughts.j-davis.com/2010/09/25/exclusion-constraints-are-
 generalized-sql-unique/
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1471#comment:1>
