[postgis-devel] [PostGIS] #1183: Retest OpenStreetMap
trac at osgeo.org
Mon Jan 16 05:20:07 PST 2012
Reporter: robe | Owner: strk
Type: task | Status: closed
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Resolution: fixed | Keywords:
Changes (by strk):
* status: assigned => closed
* resolution: => fixed
Comment:
Ok, the first issue is fixed upstream by dropping GIST_GEOMETRY_OPS, of
course older releases won't work, unless we get back to support
GIST_GEOMETRY_OPS, which I've understood you would scream about
(dump/reload).
The second issue is also fixed upstream.
I successfully tested osm2pgsql from repo.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1183#comment:3>
