[postgis-devel] Should EMPTY be spatially equal to self ?
Havard Tveite
havard.tveite at umb.no
Mon Jan 16 10:06:03 PST 2012
On 1/16/2012 2:42 PM, Sandro Santilli wrote:
> On Sat, Jan 14, 2012 at 12:44:34AM +0100, Havard Tveite wrote:
>> How would you explain the result of ST_Equals(empty,empty)
>> according to point set topology? the 9-intersection
>> model* says that "equals" has the following matrix (T:
>> non-empty, F: empty, i: interior, b: boundary, e:
>> exterior):
>> i b e
>> i T F F
>> b F T F
>> e F F T
> As I just said to regina, the above isn't always true.
> A point has no boundary, so BB can't be T.
You are right - in the above example I was simplifying to
2D geometries in 2D space. But I don't think that really
matters much in this context.
>> I suppose that empty geometries have an empty interior and
>> an empty boundary. Then their exterior would be the
>> universal set. In that case (and if the empty set is a
>> member of all sets, also for point set topology), I would
>> think that the matrix should be all T's, and that is not
>> the matrix of ST_Equals.
> There's no such thing as the "equals matrix".
There *is* such a thing as the "equals matrix" for 2D
geometries in 2D space. I think the above example is valid
for 2D geometries in 2D space, and I think that it shows a
problem with returning "true" or "false" as the result when
comparing empty geometries for spatial equality.
>> So I don't think it makes sense to return anything else than
>> NULL for ST_Equals on empty geometries.
> The sense I see about is is that ST_Equals(A, A) should be true,
> for anything which isn't NULL. If EMPTY should be threated the
> same as NULL I don't see why we have EMPTY at all.
What I say is that I think that spatial is different, and I
have tried to show this by referring to point set topology
applied to 2D geometries in 2D space.
ST_Equals is a spatial operation, and, in my opinion,
comparing anything to to empty is nonsense in a spatial
context.
I buy the argument in Paul's document that EMPTY is kind of
logical as a result of for instance ST_Intersect and
ST_Difference. Whether it is really useful to be able to
differentiate between NULL and EMPTY, I don't know.
I would guess that we could do without EMPTY.
>> In a practical situation, I would not like a spatial join
>> with ST_Equals as the join predicate to get matches when one
>> or both of the geometries are empty, since their spatial
>> relationship cannot be determined (in my opinion).
> I belive the spatial relationship of two empty geometries
> is well defined as :
> i b e
> i F F F
> b F F F
> e F F 2
I think you should justify this. Is it not so that the
empty set is a member of all sets? If the interior and
boundary of the empty set is the empty set, How come you
get so many F's in your matix?
Håvard
Håvard Tveite
Department of Mathematical Sciences and Technology, UMB
Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
