[postgis-devel] Should EMPTY be spatially equal to self ?
Paragon Corporation
lr at pcorp.us
Tue Jan 17 01:32:23 PST 2012
Wikipedia is our friend :)
http://en.wikipedia.org/wiki/DE-9IM
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On
> Behalf Of Chris Hodgson
> Sent: Monday, January 16, 2012 1:45 PM
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] Should EMPTY be spatially equal to self ?
> Just going to throw my bits into this discussion.
> >> I belive the spatial relationship of two empty geometries is well
> >> defined as :
> >> i b e
> >> i F F F
> >> b F F F
> >> e F F 2
> > I think you should justify this. Is it not so that the
> empty set is a
> > member of all sets? If the interior and boundary of the
> empty set is
> > the empty set, How come you get so many F's in your matix?
> I believe that matrix is correct. The empty set is not a
> member of all sets; if it were, the intersection between any
> two sets could never be empty. The empty set IS a subset of
> all sets; but that is not at issue here. Personally I don't
> think it is necessary to define the matrix at all.
> The reason why I believe it is necessary to have the empty
> geometry is for "geometric formulas". Consider the following,
> where A, B, and C are arbitrary geometries:
> A minus (B intersect C)
> If (B intersect C) is empty, and we return NULL, then A minus
> NULL will return NULL, leaving us with no answer. If we allow
> for (B intersect C) to return an EMPTY geometry, then we can
> proceed with A minus EMPTY and return A, which is almost
> certainly the answer we were looking for. You can replace the
> minus and intersect with whatever operations you like,
> certainly there are other even more interesting cases which
> suggest that EMPTY has a use.
> Given that this is a valid reason for having EMPTY
> geometries, and treating them with different semantics than
> NULLs, we consider what semantics we should use for EMPTY ==
> EMPTY, and it seems to me, that if you were ever doing an
> equals test where it was possible to have empty geometries on
> either side, having two empty geometries be equal is the only
> useful meaning. If you really want to attach another meaning
> is possible to do by specifically filtering for EMPTY cases -
> though the same is true either way so this doesn't lend much
> weight to my argument; if anything it should lift some weight
> from the overall decision.
> Overall it seems to me than EMPTY has more similar mechanics
> to zero than to null, and clearly 0 == 0.
> Cheers,
> Chris
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
