[postgis-devel] [PostGIS] #846: Cleaning up around and enhance point in polygon tests around the code
PostGIS trac at osgeo.org
Wed Jan 18 14:30:06 PST 2012
 Reporter:  nicklas      |       Owner:  nicklas
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.1.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
Changes (by nicklas):
  * milestone:  PostGIS 2.0.0 => PostGIS 2.1.0
Comment:
 This is connected to #852. This stopped up because I don't understand this
 "tolerance" implementation discussed in #852 and I don't want to put that
 in the point in polygon test used in distance before #852 is sorted out
 and I don't dare removing the tolerance part to clean it up that way. So,
 I shift it to 2.1 .If you find it irrelevant, just close it. Right now
 (last year) time is not enough, but I really hope to get back.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/846#comment:14>
