[postgis-devel] [PostGIS] #852: The use of tolerance in function point_in_ring is not robust.
PostGIS trac at osgeo.org
Thu Jan 19 00:30:41 PST 2012
 Reporter:  nicklas  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  1.5.X
 Keywords:           |
Comment(by strk):
 Note: the case in the original description does _not_ hit the cache, thus
 calls point_in_polygon which gets to point_in_ring.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/852#comment:6>
