[postgis-devel] PostGIS 2.0 SRID constraint
Paul Ramsey pramsey at opengeo.org
Thu Jan 19 14:42:25 PST 2012
I think we can just at the spatialreference.org folks to only add 1M
to the ESRI code instead of adding 9M. The ESRI code itself is only in
the 100K range.
P
On Thu, Jan 19, 2012 at 2:39 PM, dustymugs <dustymugs at gmail.com> wrote:
>>> I just hit this uploading some parcel data that uses an ESRI projection.
>> Example url ?
> For ESRI:102645, click on the PostGIS INSERT statement...
> http://spatialreference.org/ref/esri/102645/
> -bborie
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
