[postgis-devel] [PostGIS] #1487: extensions not installing because AddRasterConstraints doc at odds with implementation
PostGIS trac at osgeo.org
Fri Jan 20 00:27:42 PST 2012
implementation
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 Seems the AddRasterConstraints has changed since it was documented.
 Looks like all these were removed out of the end:
 boolean num_bands=true, boolean pixel_types=true, boolean
 nodata_values=true, boolean extent=true
 I'm going to assume this is an intentional change and just update the docs
 so extensions can install.
 e.g used to be
 boolean AddRasterConstraints(name rasttable, name rastcolumn, boolean
 srid, boolean scale_x, boolean scale_y, boolean blocksize_x, boolean
 blocksize_y, boolean same_alignment, boolean regular_blocking, boolean
 num_bands=true, boolean pixel_types=true, boolean nodata_values=true,
 boolean extent=true)
 now its
 blocksize_y, boolean same_alignment, boolean regular_blocking)
 This is testing Paul's very soft launched alpha1 tar ball.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1487>
