[postgis-devel] [PostGIS] #547: ST_contains memory problem when used between polygon and mixed geometry
PostGIS trac at osgeo.org
Fri Jan 20 00:46:31 PST 2012
  Reporter:  twain    |       Owner:  strk
      Type:  defect   |      Status:  closed
  Priority:  high     |   Milestone:  PostGIS 1.5.4
 Component:  postgis  |     Version:  1.5.X
Resolution:  fixed    |    Keywords:  ST_contains memory
Changes (by strk):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 r8888 fixes a missing return in trunk,
 r8887 backports the fixed version into 1.5
Ticket URL: <http://trac.osgeo.org/postgis/ticket/547#comment:11>
