[postgis-devel] regress no longer
Greg Troxel
gdt at ir.bbn.com
Fri Jan 20 18:17:00 PST 2012
As another datapoint, I am having the postgis/postgis-2.0 problem with
the regression tests. I updated, reran autogen, configure, gmake clean,
gmake, gmake check.
~/SOFTWARE/POSTGIS/postgis > find regress/00-regress-install
regress/00-regress-install/postgis.sql
regress/00-regress-install/lib
regress/00-regress-install/lib/postgis-2.0.so
regress/00-regress-install/share
regress/00-regress-install/share/contrib
regress/00-regress-install/share/contrib/postgis-2.0
regress/00-regress-install/share/contrib/postgis-2.0/spatial_ref_sys.sql
regress/00-regress-install/share/contrib/postgis-2.0/postgis.sql
regress/00-regress-install/share/contrib/postgis-2.0/uninstall_postgis.sql
regress/00-regress-install/share/contrib/postgis-2.0/postgis_upgrade_20_minor.sql
regress/00-regress-install/share/contrib/postgis-2.0/legacy.sql
regress/00-regress-install/share/contrib/postgis-2.0/uninstall_legacy.sql
regress/00-regress-install/share/contrib/postgis-2.0/legacy_compatibility_layer.sql
But from ./run_test:
/home/gdt/SOFTWARE/POSTGIS/postgis/regress/00-regress-install/share/contrib/postgis/postgis.sql: No such file or directory
and in postgis.sql (found if I add a symlink):
CREATE OR REPLACE FUNCTION spheroid_in(cstring)
RETURNS spheroid
AS '$libdir/postgis-2.0','ellipsoid_in'
LANGUAGE 'C' IMMUTABLE STRICT;
and I'm not sure how libdir is supposed to be interpreted, but I get a failure on that statement.
Before the regress rototill, I was passing the regression tests (modulo
Latin1 encoding issues). (postgresql 9.1.2, NetBSD/i386 5.1_STABLE)
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20120120/f9b7a052/attachment.sig>
