[postgis-devel] Build failed in Hudson: PostGIS-trunk-build #3760
Chris Hodgson
chodgson at refractions.net
Mon Jan 23 13:08:27 PST 2012
What version of gdal should I install on the buildbot?
Chris
On 12-01-20 03:42 PM, Paul Ramsey wrote:
> Chris,
> Could you set the buildbot to use --without-raster in its configure,
> or add gdal to it please?
> Thanks,
> P.
> On Fri, Jan 20, 2012 at 3:06 PM,<chodgson at refractions.net> wrote:
>> See<http://office.refractions.net:1500/job/PostGIS-trunk-build/3760/changes>
>> Changes:
>> [Paul Ramsey] Make raster on by default and --without-raster the configuration parameter to disable it.
>> Started by remote host 140.211.15.71
>> Updating http://svn.osgeo.org/postgis/trunk
>> U configure.ac
>> At revision 8896
>> [workspace] $ /bin/sh -xe /tmp/hudson671320016005153531.sh
>> ++ svn info src
>> ++ grep 'Last Changed Rev:'
>> ++ cut -f4 '-d '
>> + SVN_REVISION=8896
>> + rm -rf build
>> + rm -rf rel
>> + rm -rf postgis-2.0.0SVN postgis-2.0.0SVN.tar.gz
>> + svn export src rel
>> Export complete.
>> + cd ./rel
>> + ./autogen.sh
>> * Running /usr/bin/libtoolize (1.5.22)
>> OPTIONS = --force --copy
>> You should add the contents of `/usr/share/aclocal/libtool.m4' to `aclocal.m4'.
>> * Running /usr/bin/aclocal (1.9.6)
>> * Running /usr/bin/autoconf (2.59)
>> Now you are ready to run './configure'
>> + rm -rf autom4te.cache
>> + rm -rf HOWTO_RELEASE
>> + rm -rf make_dist.sh
>> + echo SVN_REVISION=8896
>> + cd<http://office.refractions.net:1500/job/PostGIS-trunk-build/ws/>
>> + svn export src build
>> Export complete.
>> + cd build
>> + ./autogen.sh
>> + ./configure --with-pgconfig=/var/home/buildbot/opt/pgsql/9.0.1/bin/pg_config --with-geosconfig=/var/home/buildbot/opt/geos/3.2.2/bin/geos-config --with-projdir=/var/home/buildbot/opt/proj/4.7.0
>> checking build system type... i686-redhat-linux-gnu
>> checking host system type... i686-redhat-linux-gnu
>> checking for gcc... gcc
>> checking for C compiler default output file name... a.out
>> checking whether the C compiler works... yes
>> checking whether we are cross compiling... no
>> checking for suffix of executables...
>> checking for suffix of object files... o
>> checking whether we are using the GNU C compiler... yes
>> checking whether gcc accepts -g... yes
>> checking for gcc option to accept ANSI C... none needed
>> checking for a sed that does not truncate output... /bin/sed
>> checking for egrep... grep -E
>> checking for ld used by gcc... /usr/bin/ld
>> checking if the linker (/usr/bin/ld) is GNU ld... yes
>> checking for /usr/bin/ld option to reload object files... -r
>> checking for BSD-compatible nm... /usr/bin/nm -B
>> checking whether ln -s works... yes
>> checking how to recognise dependent libraries... pass_all
>> checking how to run the C preprocessor... gcc -E
>> checking for ANSI C header files... yes
>> checking for sys/types.h... yes
>> checking for sys/stat.h... yes
>> checking for stdlib.h... yes
>> checking for string.h... yes
>> checking for memory.h... yes
>> checking for strings.h... yes
>> checking for inttypes.h... yes
>> checking for stdint.h... yes
>> checking for unistd.h... yes
>> checking dlfcn.h usability... yes
>> checking dlfcn.h presence... yes
>> checking for dlfcn.h... yes
>> checking for g++... g++
>> checking whether we are using the GNU C++ compiler... yes
>> checking whether g++ accepts -g... yes
>> checking how to run the C++ preprocessor... g++ -E
>> checking for g77... no
>> checking for f77... no
>> checking for xlf... no
>> checking for frt... no
>> checking for pgf77... no
>> checking for fort77... no
>> checking for fl32... no
>> checking for af77... no
>> checking for f90... no
>> checking for xlf90... no
>> checking for pgf90... no
>> checking for epcf90... no
>> checking for f95... no
>> checking for fort... no
>> checking for xlf95... no
>> checking for ifc... no
>> checking for efc... no
>> checking for pgf95... no
>> checking for lf95... no
>> checking for gfortran... no
>> checking whether we are using the GNU Fortran 77 compiler... no
>> checking whether accepts -g... no
>> checking the maximum length of command line arguments... 32768
>> checking command to parse /usr/bin/nm -B output from gcc object... ok
>> checking for objdir... .libs
>> checking for ar... ar
>> checking for ranlib... ranlib
>> checking for strip... strip
>> checking if gcc supports -fno-rtti -fno-exceptions... no
>> checking for gcc option to produce PIC... -fPIC
>> checking if gcc PIC flag -fPIC works... yes
>> checking if gcc static flag -static works... yes
>> checking if gcc supports -c -o file.o... yes
>> checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes
>> checking whether -lc should be explicitly linked in... no
>> checking dynamic linker characteristics... GNU/Linux ld.so
>> checking how to hardcode library paths into programs... immediate
>> checking whether stripping libraries is possible... yes
>> checking if libtool supports shared libraries... yes
>> checking whether to build shared libraries... yes
>> checking whether to build static libraries... yes
>> configure: creating libtool
>> appending configuration tag "CXX" to libtool
>> checking for ld used by g++... /usr/bin/ld
>> checking whether the g++ linker (/usr/bin/ld) supports shared libraries... yes
>> checking for g++ option to produce PIC... -fPIC
>> checking if g++ PIC flag -fPIC works... yes
>> checking if g++ static flag -static works... yes
>> checking if g++ supports -c -o file.o... yes
>> appending configuration tag "F77" to libtool
>> checking for gcc... (cached) gcc
>> checking whether we are using the GNU C compiler... (cached) yes
>> checking whether gcc accepts -g... (cached) yes
>> checking for gcc option to accept ANSI C... (cached) none needed
>> checking whether we are using the GNU C++ compiler... (cached) yes
>> checking whether g++ accepts -g... (cached) yes
>> checking if g++ supports -Wall... yes
>> checking if g++ supports -Wmissing-prototypes... yes
>> checking if g++ supports -ffloat-store... yes
>> checking for flex... flex
>> checking for yywrap in -lfl... yes
>> checking lex output file root... lex.yy
>> checking whether yytext is a pointer... yes
>> checking for bison... bison -y
>> checking ieeefp.h usability... no
>> checking ieeefp.h presence... no
>> checking for ieeefp.h... no
>> checking for vasprintf... yes
>> checking for asprintf... yes
>> checking for perl... /usr/bin/perl
>> checking for convert... /usr/bin/convert
>> checking for xsltproc... /usr/bin/xsltproc
>> checking for dblatex... /usr/bin/dblatex
>> checking CUnit/CUnit.h usability... yes
>> checking CUnit/CUnit.h presence... yes
>> checking for CUnit/CUnit.h... yes
>> checking for CU_initialize_registry in -lcunit... yes
>> checking iconv.h usability... yes
>> checking iconv.h presence... yes
>> checking for iconv.h... yes
>> checking for libiconv_open in -liconv... no
>> checking for iconv_open in -lc... yes
>> checking for iconvctl... no
>> checking for libiconvctl... no
>> Using user-specified pg_config file: /var/home/buildbot/opt/pgsql/9.0.1/bin/pg_config
>> checking PostgreSQL version... PostgreSQL 9.0.1
>> checking libpq-fe.h usability... yes
>> checking libpq-fe.h presence... yes
>> checking for libpq-fe.h... yes
>> checking for PQserverVersion in -lpq... yes
>> checking for xml2-config... /usr/bin/xml2-config
>> checking libxml/tree.h usability... yes
>> checking libxml/tree.h presence... yes
>> checking for libxml/tree.h... yes
>> checking libxml/parser.h usability... yes
>> checking libxml/parser.h presence... yes
>> checking for libxml/parser.h... yes
>> checking libxml/xpath.h usability... yes
>> checking libxml/xpath.h presence... yes
>> checking for libxml/xpath.h... yes
>> checking libxml/xpathInternals.h usability... yes
>> checking libxml/xpathInternals.h presence... yes
>> checking for libxml/xpathInternals.h... yes
>> checking for xmlInitParser in -lxml2... yes
>> Using user-specified geos-config file: /var/home/buildbot/opt/geos/3.2.2/bin/geos-config
>> checking GEOS version... 3.2.2
>> checking geos_c.h usability... yes
>> checking geos_c.h presence... yes
>> checking for geos_c.h... yes
>> checking for initGEOS in -lgeos_c... yes
>> checking whether make sets $(MAKE)... yes
>> checking for a BSD-compatible install... /usr/bin/install -c
>> checking whether NLS is requested... yes
>> checking for msgfmt... /usr/bin/msgfmt
>> checking for gmsgfmt... /usr/bin/msgfmt
>> checking for xgettext... /usr/bin/xgettext
>> checking for msgmerge... /usr/bin/msgmerge
>> checking for ld used by GCC... /usr/bin/ld
>> checking for shared library run path origin... done
>> checking for CFPreferencesCopyAppValue... no
>> checking for CFLocaleCopyCurrent... no
>> checking for GNU gettext in libc... yes
>> checking whether to use NLS... yes
>> checking where the gettext function comes from... libc
>> Using user-specified proj directory: /var/home/buildbot/opt/proj/4.7.0
>> checking proj_api.h usability... yes
>> checking proj_api.h presence... yes
>> checking for proj_api.h... yes
>> checking for pj_get_release in -lproj... yes
>> checking json/json.h usability... no
>> checking json/json.h presence... no
>> checking for json/json.h... no
>> checking for json_object_get in -ljson... no
>> Could not open input file sqlmm.sql.in.c
>> checking for GDAL>= 1.6.0... which: no gdal-config in (/usr/kerberos/bin:/usr/local/bin:/bin:/usr/bin:/var/home/buildbot/bin)
>> not found
>> configure: error: gdal-config not found. With --without-raster or try --with-gdalconfig=<path to gdal-config>
>> Archiving artifacts
