[postgis-devel] [PostGIS] #1405: Hudson should run make check	RUNTESTFLAGS='-v'
    trac at osgeo.org
    Mon Jan 23 16:29:54 PST 2012
  Reporter:  strk        |       Owner:  chodgson
      Type:  task        |      Status:  closed
  Priority:  medium      |   Milestone:  PostGIS 2.0.0
 Component:  management  |     Version:  trunk
Resolution:  fixed       |    Keywords:
Changes (by chodgson):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 I modified regress.sh, which is used for the majority of the regression
 tests (if not all) to include this parameter to make check. Haven't had a
 successful regression test since...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1405#comment:1>
