[postgis-devel] Raster Regression on Hudson
dustymugs dustymugs at gmail.com
Mon Jan 23 16:58:23 PST 2012
Chris,
Those error messages are expected from testapi.  It would be better to
use the return status from the testapi test.
-bborie
On 01/23/2012 04:54 PM, Chris Hodgson wrote:
> Hudson is complaining about the ERROR: messages being output in the
> following snippet... are they expected errors?
> I don't think this was being output before I added the RUNTESTFLAGS='-v'
> I'd love to get a clean full build and regression so that I can confirm
> I've got Hudson working properly.
> Chris
> ./testapi
> Checking empty and hasnoband functions...
> Checking raster properties...
> Raster starts with 0 bands
> First point on convexhull ring is 0.5,0.5
> Second point on convexhull ring is 256.5,1280.5
> Third point on convexhull ring is 1280.5,1536.5
> Fourth point on convexhull ring is 1024.5,256.5
> Fifth point on convexhull ring is 0.5,0.5
> Testing polygonize function
> Testing 1BB band
> Testing 2BB band
> Testing 4BUI band
> Testing 8BUI band
> Testing 8BSI band
> Testing 16BSI band
> ERROR: rt_band_set_pixel: Coordinates out of range
> Testing 16BUI band
> Testing 32BUI band
> Testing 32BSI band
> Testing 32BF band
> Testing 64BF band
> Testing band hasnodata flag
> Testing rt_raster_from_band
> Successfully tested rt_raster_from_band
> Testing band stats
> Successfully tested band stats
> Testing rt_raster_replace_band
> Successfully tested rt_raster_replace_band
> Testing rt_band_reclass
> Successfully tested rt_band_reclass
> Testing rt_raster_to_gdal
> Successfully tested rt_raster_to_gdal
> Testing rt_raster_gdal_drivers
> Successfully tested rt_raster_gdal_drivers
> Testing rt_band_get_value_count
> Successfully tested rt_band_get_value_count
> Testing rt_raster_from_gdal_dataset
> Successfully tested rt_raster_from_gdal_dataset
> Testing rt_raster_gdal_warp
> Successfully tested rt_raster_gdal_warp
> Testing rt_raster_gdal_rasterize
> Successfully tested rt_raster_gdal_rasterize
> Testing rt_raster_intersects
> Successfully tested rt_raster_intersects
> Testing rt_raster_same_alignment
> Successfully tested rt_raster_same_alignment
> Testing rt_raster_from_two_rasters
> ERROR: rt_raster_from_two_rasters: The two rasters provided do not have
> the same alignment
> the same SRID
> the same alignment
> Successfully tested rt_raster_from_two_rasters
> Testing rt_raster_load_offline_band
> Successfully tested rt_raster_load_offline_band
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
