[postgis-devel] [PostGIS] #1405: Hudson should run make check RUNTESTFLAGS='-v'
trac at osgeo.org
Tue Jan 24 11:54:30 PST 2012
Reporter: strk | Owner: chodgson
Type: task | Status: closed
Priority: medium | Milestone: PostGIS 2.0.0
Component: management | Version: trunk
Resolution: fixed | Keywords:
Changes (by chodgson):
* status: reopened => closed
* resolution: => fixed
Comment:
I've modified the regress script to now catch the return code from the
make check call and output something which can be grep'd by the hudson
script that calls it. Also removed another check from the hudson script
which was broken. Hopefully we will catch all the failures and have
minimal false positives after these changes. The output resulting from the
"-v" option can now be seen in the console output from hudson.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1405#comment:4>
