[postgis-devel] raster regression failures
Greg Troxel gdt at ir.bbn.com
Wed Jan 25 16:28:58 PST 2012
I get two failures on the raster regression tests with:
  PostGIS is now configured for i386-unknown-netbsdelf5.1.
 -------------- Compiler Info -------------
  C compiler:           gcc -g -O2
  C++ compiler:         g++ -g -O2
 -------------- Dependencies --------------
  GEOS config:          /usr/pkg/bin/geos-config
  GEOS version:         3.3.2
  GDAL config:          /usr/pkg/bin/gdal-config
  GDAL version:         1.8.0
  PostgreSQL config:    /usr/pkg/bin/pg_config
  PostgreSQL version:   PostgreSQL 9.1.2
  PROJ4 version:        47
  Libxml2 config:       /usr/pkg/bin/xml2-config
  Libxml2 version:      2.7.8
  JSON-C support:       no
  PostGIS debug level:  0
  Perl:                 /usr/pkg/bin/perl
 --------------- Extensions ---------------
  PostGIS Raster:       0.1.6d
  PostGIS Topology:     enabled
 -------- Documentation Generation --------
  xsltproc:             /usr/pkg/bin/xsltproc
  xsl style sheets:     /usr/pkg/share/xsl/docbook
  dblatex:
  convert:              /usr/pkg/bin/convert
The diffs follow, but basically I seem to get NaN instead of a value.  I
ran "paranoia"*, which when compiled with -ffloat-store was totally happy
with my compiler/library/processor's arithmetic.  So, while realizing
that my results seem off, I wonder if
  anyone else sees this
  if the tests assume i386 extended double registers
  if the tests are known to pass on non-i386 (eg. sparc64) with a
  different floating point implementation
  anyone has any other clues
I will update gdal and retry, but 1.8.0 is >= 1.6.0 which is documented
to work.
--- rt_rotation_expected	2012-01-12 20:47:29.000000000 -0500
+++ /tmp/pgis_reg_14681/test_18_out	2012-01-25 19:12:25.000000000 -0500
@@ -1,8 +1,8 @@
-4|1x1, ip:7.5,2.5 scale:5,5 skew:1,1, srid:-1, width:1, height:1|0.197395559849881
+4|1x1, ip:7.5,2.5 scale:5,5 skew:1,1, srid:-1, width:1, height:1|NaN
 5|1x1, ip:7.5,2.5 scale:5,5 skew:3,7, srid:-1, width:1, height:1|NaN
 104|5.09901951359278|5.09901951359278|0|0|0
 105|8.60232526704263|5.8309518948453|0|0|0
-104|3.60555127546399|3.60555127546399|3.60555127546399|3.60555127546399|0.785398163397448
-105|6.08276253029822|4.12310562561766|4.12310562561766|6.08276253029822|0.785398163397448
-104|4.41588043316392|4.41588043316392|2.54950975679639|2.54950975679639|0.523598775598299
-105|7.44983221287567|5.04975246918104|2.91547594742265|4.30116263352131|0.523598775598299
+104|3.60555127546399|3.60555127546399|3.60555127546399|3.60555127546399|NaN
+105|6.08276253029822|4.12310562561766|4.12310562561766|6.08276253029822|NaN
+104|4.41588043316392|4.41588043316392|2.54950975679639|2.54950975679639|NaN
+105|7.44983221287567|5.04975246918104|2.91547594742265|4.30116263352131|NaN
--- rt_mapalgebrafctngb_userfunc_expected	2012-01-12 20:47:29.000000000 -0500
+++ /tmp/pgis_reg_14681/test_48_out	2012-01-25 19:12:31.000000000 -0500
@@ -26,6 +26,6 @@
 t|t
 t|t
 t|t
-t|t
+ERROR:  input is out of range
 t
 t
* http://www.netlib.org/paranoia/
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20120125/3062d62c/attachment.sig>
