[postgis-devel] [PostGIS] #1504: Segfault running ST_EstimatedExtent()
PostGIS trac at osgeo.org
Fri Jan 27 07:47:22 PST 2012
 Reporter:  brushtyler  |       Owner:  pramsey
     Type:  defect      |      Status:  new
 Priority:  blocker     |   Milestone:  PostGIS 2.0.0
Component:  postgis     |     Version:  trunk
 Keywords:              |
Comment(by brushtyler):
 yes, the server crashes even running that query from psql.
 Anyway the original query was:
 test=> SELECT st_xmin(extent), st_ymin(extent), st_xmax(extent),
 st_ymax(extent) FROM (SELECT st_estimated_extent('city_data','face','mbr')
 AS extent) AS subquery;
 The connection to the server was lost. Attempting reset: Failed.
 instead running the query above I get:
 test=> SELECT st_estimated_extent('city_data','face','mbr') AS extent;
 The connection to the server was lost. Attempting reset: Succeeded.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1504#comment:2>
