[postgis-devel] [PostGIS] #1504: Segfault running ST_EstimatedExtent()
trac at osgeo.org
Fri Jan 27 11:59:43 PST 2012
Reporter: brushtyler | Owner: pramsey
Type: defect | Status: reopened
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Changes (by brushtyler):
* status: closed => reopened
* resolution: invalid =>
Comment:
I've found a way to reproduce it:
test=> CREATE TABLE "test_1504" (id int PRIMARY KEY, geom
geometry(LineString,3003));
NOTICE: CREATE TABLE / PRIMARY KEY will create implicit index
"test_1504_pkey" for table "test_1504"
CREATE TABLE
test=> INSERT INTO "test_1504" (id, geom) VALUES (0, NULL);
INSERT 0 1
test=> ALTER TABLE "test_1504" ALTER COLUMN geom TYPE geometry(LineString,
-1);
NOTICE: SRID value -1 converted to the officially unknown SRID value 0
ALTER TABLE
test=> select st_estimated_extent('test_1504', 'geom');
The connection to the server was lost. Attempting reset: Failed.
NB: I tried to add with a geometry not NULL, but I got the same result
(segfault).
After reconnecting and querying the table to get srid it returns a strange
result:
test=> select st_srid(geom) from "test_1504";
st_srid
(1 row)
I think that pg_dump now returns that strange (and maybe random) srid >
MAX_SRID.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1504#comment:15>
