[postgis-devel] [PostGIS] #1506: [raster] ST_Quantile('rastertable' ...) segfault and is missing in documentation
trac at osgeo.org
Fri Jan 27 13:30:42 PST 2012
documentation
Reporter: joanw | Owner: dustymugs
Type: defect | Status: closed
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: 2.0.x
Resolution: fixed | Keywords:
Comment(by pracine):
In this case you set the flag to false even if what you are setting is
only nodata and you loose the optimization. You can ST_Rescan() all the
rasters to reset the flag once a week if you do a lot of edit (like a SQL
VACUUM). This is ONLY if you edit the rasters, which is a fraction of the
applications. Other application always get the optimization. This is what
I discussed with Jorge.
A lot of code and changes for not much optimization for coverages having
at least one tile complete with nodata which are not all of them... Really
a low priority.
I'm glad that this argument discard the idea of having empty tiles when
only filled with nodata. You would also have to check for every edited
pixel in order to determine if the resulting tile is all nodata to make it
empty...
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1506#comment:9>
