[postgis-devel] [PostGIS] #1292: ST_SnapToGrid returns a value out of range
trac at osgeo.org
Mon Jan 30 17:36:07 PST 2012
Reporter: realityexists | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by realityexists):
OK, I see - thanks for the detailed explanation! It totally makes sense
from an implementation point of view, but totally doesn't from the user
point of view. Agreed - it's tricky. The entire point of me calling
ST_SnapToGrid is to "round" the coordinates - I would never expect it to
increase the precision. Having the cast to geography automatically wrap
might be a nice thing in general, but it wouldn't solve this particular
problem*. I can't see any user expecting 'POINT(180 50)' to snap to
'POINT(-179.9999999 50)' or even to 'POINT(-180 50)' (for ''any'' snap
size value). The only result a user would expect here is 'POINT(180 50)'.
So I don't think that 180plusabit is "correct", it just isn't "incorrect
enough" to matter in most cases.
Maybe ST_SnapToGrid() can err on the side of 180minusabit here somehow? Or
maybe the cast to geography (and any other functions that check the range)
can treat 180plusabit as equal to 180? For the latter to work the epsilon
used would have to be greater than any imprecision that any snap size
could ever create, so the former sounds safer to me.
*) Yes, for larger snap size values that don't fit evenly into 180
wrapping becomes a genuine user issue, not just an implementation issue.
Eg.
ST_SnapToGrid(ST_GeomFromText('POINT(180 50)', 4326), 7)
returns 'POINT(182 50)' Should that fail or wrap when cast to geography?
I'd say it should wrap, but that's probably outside the scope of this
ticket.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1292#comment:4>
