[postgis-devel] ST_Value performance
Sandro Santilli
strk at keybit.net
Tue Jan 31 14:14:01 PST 2012
On Tue, Jan 31, 2012 at 05:04:54PM -0500, Pierre Racine wrote:
> > It would take a set of (x,y,band,value) or (geometry,band,value) in input and
> > incrementally transform a raster to set the values.
> > Didn't really think about how you can initialize an aggregate function to provide
> > a target dimension for the output raster.
> I don't know how ST_AsRaster react when you pass it a point. If it produce a 1 pixel raster (that's what I would expect) then you could try:
> SELECT ST_Union(ST_AsRaster(geometry, alignment info,...))
> FROM your table
I have the 1-pixel tiles already, ST_Union is actually running like this:
CREATE TABLE chenyx06a_single AS
SELECT ST_AddBand(null, ARRAY[
st_union(rast,1),
st_union(rast,2),
st_union(rast,3),
st_union(rast,4)
FROM chenyx06a;
The chenyx06a contains ~200k 1x1 4-bands rasters.
It's been running for over 10 minutes as I write...
--strk;
,------o-.
| __/ | Thank you for PostGIS-2.0 Topology !
| / 2.0 | http://www.pledgebank.com/postgistopology
`-o------'
