[postgis-devel] [PostGIS] #1517: VACUUM cannot be executed from a function or multi-command string
    trac at osgeo.org
    Tue Jan 31 18:06:56 PST 2012
 Reporter:  realityexists  |       Owner:  pramsey
     Type:  defect         |      Status:  new
 Priority:  medium         |   Milestone:  PostGIS 2.0.0
Component:  postgis        |     Version:  trunk
 Keywords:                 |
 When I run spatial_ref_sys.sql in pgAdmin it returns an error:
 Looks like the same problem as ticket #333, but in revision 8990.
 Commenting out the word "VACUUM" on the last line of the file resolves the
 problem.
 The same error occurs when running "CREATE EXTENSION postgis".
 Running on Ubuntu 11.04 x86, PostgreSQL 9.1.1
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1517>
