[postgis-devel] [PostGIS] #1518: Report SVN revision in PostGIS_Full_Version
trac at osgeo.org
Tue Jan 31 19:19:35 PST 2012
Reporter: realityexists | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
It would be helpful if there was a way to find the exact PostGIS version,
including the SVN revision it was built from, in SQL.
PostGIS_Full_Version() reports "2.0.0SVN" or similar, but not the
revision.
Sometimes our application relies on a particular bug fix, which we know
was made in a particular revision. If an earlier version of PostGIS is
used it may run for hours before failing, so I'd like to check the version
at the start and fail immediately if it's not right. I currently do this
by testing for the bug directly, but that kind of check doesn't really
belong in production code. Checking the version would be simpler and
cleaner.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1518>
