[postgis-devel] [PostGIS] #1894: Documentation test failure
PostGIS trac at osgeo.org
Mon Jul 2 12:51:47 PDT 2012
 Reporter:  strk           |       Owner:  robe
     Type:  defect         |      Status:  new
 Priority:  medium         |   Milestone:  PostGIS 2.0.2
Component:  documentation  |     Version:  2.0.x
 Keywords:                 |
Comment(by robe):
 I didn't know there was a doc check.  You can check strk -- you have the
 power :)
 I know that it runs the make checks separate from the make.  I think it
 does make, deploy job, and then a regress as a separate job.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1894#comment:5>
