[postgis-devel] [PostGIS] #1899: TIN to topology : ERROR: Unexpected feature dimension 2
PostGIS trac at osgeo.org
Tue Jul 3 08:22:01 PDT 2012
 Reporter:  strk      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.2
Component:  topology  |     Version:  2.0.x
 Keywords:            |
 Just a weird error message when you try to import a TIN using toTopoGeom
 into an areal layer:
 It is weird because we do expect a feature of dimension 2 into an areal
 layer...
 Note that the same TIN represented as a MULTIPOLYGON imports fine.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1899>
