[postgis-devel] [PostGIS] #1828: Estimate returned by geography_gist_selectivity results in slow query plan for ST_DWithin
trac at osgeo.org
Tue Jul 3 10:27:48 PDT 2012
for ST_DWithin
Reporter: realityexists | Owner: mcayland
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.2
Component: postgis | Version: 2.0.x
Keywords: |
Comment(by mcayland):
Bear in mind that the comment block is misleading - we're not bailing out
because we have <const> && <const> because there is no such clause in the
generated SQL. If you look closer at the code beforehand, the reason we're
dropping into that section is because we have something that's not <var>
&& <const> or <const> && <var>, which in this case is caused by <const> &&
<func> created by the _st_expand(pos, 300000) clause.
The only reason this works for your case above is because it just so
happens that 300000 covers the entire histogram area and so a selectivity
of 1.0 is an appropriate value. If you change this to, say 300, then the
selectivity will become inaccurate once again.
I wonder if we can create a slightly modified _st_expand() function with
different prototypes for different arguments, e.g.
_st_expand(const, distance) -> returns the geography with expanded box as
it (should) do at the moment
_st_expand(col, distance) -> uses the histogram stats to return the
bounding box for the given column and then expand it by distance
If we mark this second function as IMMUTABLE then it should get folded
into a constant at plan time, and then we can use this to set search_box
by detecting this <const> && <const> condition which might stand a chance
of returning something slightly meaningful.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1828#comment:38>
