[postgis-devel] [PostGIS] #1900: Fix pgsql2shp for big-endian systems
trac at osgeo.org
Tue Jul 3 19:56:37 PDT 2012
Reporter: rroliver | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.0.2
Component: postgis | Version: 2.0.x
Keywords: pgsql2shp bigendian |
pgsql2shp has been broken for all 2.0.0 versions (since r5828) on all big-
endian systems.
Specifying the column name _geoX for the geometry column was neglected in
the main scan query for big-endian systems, causing breakage in
ShpLoaderGenerateShapeRow as this is the column name searched for to
retrieve the geometry column number (geocolnum).
Symptoms of issue are empty shapefile output and the error msg
"column number -1 is out of range 0..x"
for every row in table.
Patch attached
Tested and working on Solaris Sparc (32 and 64)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1900>
