[postgis-devel] [PostGIS] #1901: PostGIS 2.0.0 - Errors during "make check"
PostGIS trac at osgeo.org
Wed Jul 4 08:02:03 PDT 2012
 Reporter:  davidMF  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.2
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
 Hye.
 I've installed PostGIS 2.0.0 on RHEL6.
 I succeed in creating PostGIS extension but the check is not ok.
 I tried "make check" but it crashed with a lot of errors messages.
 (PS : my conf in detail =>
 POSTGIS="2.0.0 r9605" GEOS="3.3.2-CAPI-1.7.2" PROJ="Rel. 4.8.0, 6 March
 2012" GDAL="GDAL 1.9.1, released 2012/05/15" LIBXML="2.7.7"
 LIBJSON="UNKNOWN" TOPOLOGY RASTER).
 The first error:
 error : Operation in progress
 postgis-out.xml:11: warning: failed to load external entity
 "http://www.w3.org/Math/DTD/mathml2/mathml2.dtd"
 %mathml;
 Entity: line 1:
  %mathml;
 using_postgis_dataman.xml:1372: namespace error : Namespace prefix mml on
 math is not defined
                       <mml:math display="block">
 The last one:
 using_postgis_dataman.xml:1494: element inlineequation: validity error :
 Element inlineequation content does not follow the DTD, expecting (alt? ,
 (inlinegraphic+ | inlinemediaobject+ | mml:math)), got (math )
                     </inlineequation></emphasis></entry>
 make[1]: *** [check] Erreur 4
 make[1]:  « /var/lib/pgsql/distribs/POSTGIS/POSTGIS/postgis-2.0.0/doc »
 make: *** [docs-check] Error 2
 Thanks for your help.
 David.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1901>
