[postgis-devel] [PostGIS] #1901: PostGIS 2.0.0 - Errors during "make check"
trac at osgeo.org
Thu Jul 5 06:20:34 PDT 2012
Reporter: davidMF | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.2
Component: postgis | Version: 2.0.x
Keywords: |
Comment(by robe):
Are you building from SVN or tar ball? If building from tarball, you
should be able to make check without generating docs, however you may need
to set the --with-xsldir to something bogus:
--with-xsldir=/pleaseno
so it registers as not found. See: #1779
Also you are trying to install an obsolete version. 2.0.1 came out
recently which includes a lot of bug fixes:
http://www.postgis.org/news/20120622
Please try that one and see if you still have issues.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1901#comment:4>
