[postgis-devel] [PostGIS] #1901: PostGIS 2.0.0 - Errors during "make check"
PostGIS trac at osgeo.org
Thu Jul 5 07:33:50 PDT 2012
 Reporter:  davidMF  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.2
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
Comment(by davidMF):
 I don't succeed in compiling because of security policies which don't
 allow acces to external web sites.
 Today (5 hours ago), I tried compiling with Postgis 2.0.1
 I got ==>
 POSTGIS="2.0.1 r9979" GEOS="3.3.2-CAPI-1.7.2" PROJ="Rel. 4.8.0, 6 March
 2012" GDAL="GDAL 1.9.1, released 2012/05/15" LIBXML="2.7.6"
 LIBJSON="UNKNOWN" TOPOLOGY RASTER
 'make was ok', but 'make check' not only.
 Else, how can I install mathml2.dtd locally ?
 I got it with an unsecured wget access and I copied it in /usr/....
 'make' was ok but 'make check' gave me others errors.
 I'm not sure that just copy this file under this directory is sufficient
 I going to test the option you gave me (--with-xsldir=/pleaseno).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1901#comment:6>
