[postgis-devel] [PostGIS] #1902: [raster] GDAL Surfer export creates files with minY and maxY swapped in header.
PostGIS trac at osgeo.org
Thu Jul 5 13:38:07 PDT 2012
header.
 Reporter:  febi              |       Owner:  pracine
     Type:  defect            |      Status:  new
 Priority:  medium            |   Milestone:  PostGIS 2.0.2
Component:  raster            |     Version:  2.0.x
 Keywords:  raster GSBG GSAG  |
Comment(by dustymugs):
 Which version of GDAL are you running?  Also, is the value for scale Y
 negative or positive?  Typically, scale Y is negative thereby having the Y
 coordinate of upper-left corner be maxY.  If scale Y is positive, the Y
 coordinate of the upper-left corner would be minY.
 ST_AsGDALRaster is pretty bare and acts only as a pass-through function to
 GDAL's CreateCopy() of the requested format.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1902#comment:1>
