[postgis-devel] [PostGIS] #1903: Crash when inserting ~280 GEOGRAPHY POINTs (and NULLs) into a GIST indexed table
PostGIS trac at osgeo.org
Fri Jul 6 06:56:51 PDT 2012
table
 Reporter:  renefournier                        |       Owner:  pramsey
     Type:  defect                              |      Status:  new
 Priority:  critical                            |   Milestone:  PostGIS 1.5.4
Component:  postgis                             |     Version:  1.5.X
 Keywords:  postgis crash gist geography point  |
Description changed by pramsey:
Old description:
> Creating a table with a GIST index on the GEOGRAPHY(POINT,4326) column,
> and then inserting hundreds rows, PostgreSQL will crash every time at row
> 284 (changing the order of the rows will affect at which row the crash
> occurs -- appears to be dependent on cumulative data size). If I remove
> the index, the crash never occurs.
>                                        postgis_full_version
>  POSTGIS="1.5.4" GEOS="3.3.2-CAPI-1.7.2" PROJ="Rel. 4.8.0, 6 March 2012"
> LIBXML="2.7.8" USE_STATS
> Log output:
> LOG:  server process (PID 1373) was terminated by signal 11: Segmentation
> fault
> LOG:  terminating any other active server processes
> WARNING:  terminating connection because of crash of another server
> process
> DETAIL:  The postmaster has commanded this server process to roll back
> the current transaction and exit, because another server process exited
> abnormally and possibly corrupted shared memory.
> HINT:  In a moment you should be able to reconnect to the database and
> repeat your command.
> LOG:  all server processes terminated; reinitializing
> LOG:  database system was interrupted; last known up at 2012-07-06
> 10:46:58 CEST
> LOG:  database system was not properly shut down; automatic recovery in
> progress
> LOG:  redo starts at 0/38E6268
> LOG:  record with zero length at 0/393AB08
> LOG:  redo done at 0/393AAC8
> LOG:  last completed transaction was at log time 2012-07-06
> 10:47:17.590389+02
> LOG:  database system is ready to accept connections
> LOG:  autovacuum launcher started
New description:
 Log output:
 fault
 process
 DETAIL:  The postmaster has commanded this server process to roll back the
 10:46:58 CEST
 progress
 10:47:17.590389+02
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1903#comment:5>
