[postgis-devel] [PostGIS] #1908: crasher with 2 geography columns in view used in query
trac at osgeo.org
Mon Jul 9 22:41:51 PDT 2012
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.2
Component: postgis | Version: 2.0.x
Keywords: |
I'm having a crasher using a view that has two geography columns.
Running the view works fine but when incorporated into thiss particular
query
Gives this message in the logs before the process kills the service
server process (PID 5448) exited with exit code 128
I'm going to try to reduce it down to the elements, but writing this here
to remind myself.
It's a funny thing because the query we have doesn't even use geography -
no output of it and even if I stuff a spatial distance output in the view
it doesn't crash when used by this query.
I had put in the geography columns for a different use but when we have it
in the view that this query uses, it consistently crashes. When we take
geography columns out of the view it works fine.
This is with PostGIS 2.0.1. and I had revised the view recently to include
more columns (including 2 geogs) and to my shock our app kept crashing the
PostgreSQL service when this key search query was run.
It's a query involving time ranges and other sub selects, but no spatial
part. My first guess is it has something to do with the self-join and
many geogs.
So the view itself -- runs fine -- it joins twice with an airports table
that has geog (one for each side of a trip).
Then the query it self that is crashing joins twice with the view, but
never selects the geog columns or even uses them.
Platform:
Windows 2008 64-bit running:
PostgreSQL 9.1.4, compiled by Visual C++ build 1500, 32-bit
POSTGIS="2.0.1 r9979" GEOS="3.3.5-CAPI-1.7.5" PROJ="Rel. 4.8.0, 6 March
2012" GDAL="GDAL 1.9.1, released 2012/05/15" LIBXML="2.7.8"
LIBJSON="UNKNOWN" RASTER
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1908>
