[postgis-devel] [PostGIS] #1908: crasher with 2 geography columns in view used in query
trac at osgeo.org
Tue Jul 10 10:01:46 PDT 2012
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.2
Component: postgis | Version: 2.0.x
Keywords: |
Comment(by robe):
I know. That's cause I'm still working on a small test to replicate the
issue. I'm avoiding the issue in our code at the moment by removing the
geography columns from the view. None of the sub queries run separately
triggers the bug. It's only in unison that it crashes.
I suppose I could try removing the index from the airports table to see if
its an issue with the index. Though the query in question I don't think
ever uses the spatial index.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1908#comment:2>
