[postgis-devel] [PostGIS] #1925: lwgeom_estimate.c: In function 'LWGEOM_gist_joinsel'
PostGIS trac at osgeo.org
Wed Jul 18 07:55:20 PDT 2012
 Reporter:  koshak                                 |       Owner:  pramsey
     Type:  defect                                 |      Status:  new
 Priority:  medium                                 |   Milestone:  PostGIS 1.5.5
Component:  postgis                                |     Version:  1.5.X
 Keywords:  lwgeom_estimate.c LWGEOM_gist_joinsel  |
Comment(by pramsey):
 So you're saying that
 /usr/local/include/postgresql/server/catalog/pg_class.h
 exists? That's the path the compile step is searching for, but it's not
 the path you put in above.
 How many instances of pg_config are on your system? (Look, this isn't a
 postgis issues, it's a "your system" issue. You've almost certainly got
 several installations of pgsql stuff lying around conflicting with one
 another, so your postgis build is looking for components in places they
 don't exist anymore)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1925#comment:4>
